Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Re-Speed
Re-Speed www.re-speed.com (GA) Custom rotary parts, specializing in 85-older
Old 02-04-2009, 08:42 PM   #1
P71
P71's Avatar
Caster/Camber kit
Billy,
I'm doing some suspension work on my 83 GSL for this autocross season and I'm interested in your C/C kit. Is this something I'll be able to install on my own or am I going to need cutting /welding? Compatible with Tokico HP (non-adjustable) and RB springs? Running 14" LE meshies with 195 Azenis, so rubbing shouldn't be a problem.
Any kind of RCC special or groupbuy?
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
Old 02-04-2009, 09:47 PM   #2
Kentetsu
Kentetsu's Avatar
Michael
I installed Billy's camber plates year before last. Very simple job. Just keep in mind that with stock sized springs you will be limited in movement, which will restrict how much camber you can get out of them. I got enough adjustment to make a very noticeable difference when I was running RB springs, but once I moved up to coilovers (smaller diameter springs) I had all the adjustment I could ever need. For autocross, I'm running probably about 75% of the camber available to me. But don't feel like you need to wait until you have coilovers to add the camber plates, they're still well worth it when used in conjunction with stock sized springs. Excellent quality part too (of course).
