Old 02-10-2013, 05:33 AM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Spark plugs
As per TED's request.
What spark plugs do you use? are you not experienced and still go of backwards Mazda OEM recommendations for your engine or have you used something else with great results?
Post and or argue away! open shit fight allowed
I do not use garbage Mazda oem recommendations, reasons are numerous but needless to say better results in every criteria can be achieved with different spark plug specifications.
My favorites are
Ghetto spec > NGK B*EGV
Mild ghetto spec > NGK B*EGP
Don Mega Spec > NGK R7420 *
* denotes various heat ranges.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-10-2013, 05:37 AM   #2
RICE RACING
Don Mega
I also like using Nippon Denso, need to go through my plethora of spark plug boxes to get you the exact number (maybe I will hide it lol since not many people know about them on the interwebz of shit lol), but its a semi bespoke racing plug which is CNC machined for rotaries, works very well, equiv to the R7420 range in NGK.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-10-2013, 05:56 AM   #3
RICE RACING
Don Mega
http://www.rx7club.com/single-turbo-...1016900/page3/
LO fucking L! at the tards in this ^ linked thread!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-10-2013, 01:01 PM   #4
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Thanks for the info. I'm not making enough power to need the high end plugs , but it's good to know your reasoning behind the use of certain plugs.
Old 02-10-2013, 02:36 PM   #5
ninesixtwo
sumdumguy
ninesixtwo is on a distinguished road
R7420 10.5L 11T for me
ninesixtwo is offline   Reply With Quote
Old 02-10-2013, 10:51 PM   #6
B.G
B.G is on a distinguished road
So even when running fairly original power, you'd recommend not going with the BUR7EQP and 9 pairing? Just bought new Magnecor plug wires and two sets of those plugs ( ?) without really getting into what the differences between the different plugs are at all, planning to eventually get an HKS ignition amplifier as well. Also got a Power FC, running slightly rich.
Going for reliability more so than power. Just want what's the healthiest for my baby Got any recommendations, Rice? Just bought my FD now in January, long term plans for it are getting a nice V-mount setup, water/meth injection, ignition amp, blocking out the OMP + going for premixing.
B.G is offline   Reply With Quote
Old 02-10-2013, 11:11 PM   #7
RICE RACING
Don Mega
For your set up > R7420 in 10 heat range once you get the HKS DLI.
Reliable plug I have many hundreds in service, never ever had a failure of a spark plug. And in every case the plugs work better in every measure you care to apply.
I have proven these to be the best plug.
E-Bay them there are plenty for sale.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-11-2013, 02:28 AM   #8
Dannobre
Dannobre is on a distinguished road
R6725-10.5/11?
Dannobre is offline   Reply With Quote
Old 02-11-2013, 04:18 AM   #9
RICE RACING
Don Mega
Originally Posted by Dannobre View Post
R6725-10.5/11?
^ These are over 30+ years old.
Platinum Platinum combo out of an old Racing Beat catalog lol......... the later R7420 Iridium center option is far superior, much longer lasting and better performing.
It is an acceptable plug, but just not as good as the one I have been using for the last 10 years.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-11-2013, 08:56 AM   #10
infernosg
IT'S ALIVE!
infernosg's Avatar
So I suppose four of the R7420-9's would be the best choice for a moderately powered N/A engine (200+ whp @ 9000+ RPM)? I stumbled across these a while back but I always assumed they were race-only plugs (i.e. warm up on stock plugs and swap 'em in).
Old 02-11-2013, 09:27 AM   #11
B.G
Awesome, thanks!
No idea if it makes a difference, but will these work equally well in cold outdoor temperatures? I noticed you live in Australia, I live in Norway..
And they won't require a much longer warmup will they? There might be times I need to drive it short distances.
Old 02-11-2013, 03:33 PM   #12
RICE RACING
Don Mega
Awesome, thanks!
I live in Alpine regions of Australia where it is common to be -10 deg C.
The 10 and 11 heat range plugs work totally fine in those conditions, you just need a properly calibrated engine map that is set to work in all operating conditions.
With a proper CDI ignition system (leave inductive for the chumps of the world!) there is never any need to worry about the garbage of a warm up then race plug, that is plain idiotic.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-11-2013, 06:53 PM   #13
B.G
Sounds good!
Sent you PM earlier btw, not sure if you saw that. Was very OT so figured it was better to send it privately
Old 02-12-2013, 06:23 AM   #14
Libor
Libor is on a distinguished road
Its not about power level. Real advantages of these high end plugs are far better durability and lower voltage requirements for given air gap compared to plugs with more conventional and bigger diameter electrodes.
Less energy you dissipate to create spark, more you have available to create plasma channel - heat which initiates flame front. Fine electrode plugs are also more consistent in sparking which lowers cycle to cycle variation which in turn means more power and better fuel economy.
Libor is offline   Reply With Quote
Old 02-12-2013, 01:00 PM   #15
mazpower
Rawr Bearclaw
mazpower's Avatar
What about using the R7420's with water/meth? From my understanding there is still platinum in those plugs, and doesn't that react with methanol causing pre-ignition? Any suggestions for someone running water/meth injection?
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
