Old 08-22-2012, 07:53 PM   #1
therex
therex is on a distinguished road
battery drain
so ever since i got the car theres been a battrey drain and ive been searching for it ever since.
i tested the alt and got a new battery(free) no luck, there was no wire from the harness going into the back of the alt to trigger to charge. positive cable is fine. i had a wire fromt he harness to the back, but still no luck.
now i have a wire from the back of the alt commected to the positive cable, still no luck,charges when i drive though.
hooked up a voltmeter, theres 6 volts of draw when the negative is unhooked, started pulling puses, ended up being my hazard fuse so ill just leave it out. but i also had the alt wire disconnected,
i now have it connected with the fuse out and it still drawing power and im not too sure what to do
any thoughts?
therex is offline   Reply With Quote
Old 08-22-2012, 08:24 PM   #2
FC Zach
FC Zach's Avatar
Did you have the alternator tested on or off the car? I think the bench testers are more accurate, still not 100% though. I've seen some that test good and the alternator still have an issue.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-22-2012, 08:57 PM   #3
therex
i had it off and took it to autozone, passed 3 out of 3
Old 08-23-2012, 02:41 AM   #4
FC Zach
FC Zach's Avatar
That narrows that down but just to be sure did you see if there was a current draw with the alternator completely disconnected?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 08-23-2012, 01:17 PM   #5
therex
tested it with out positive cable, there was only a .58 draw and with it on was the same thing .58 but now i have no way for the battery to charge...
Old 08-23-2012, 05:45 PM   #6
Pete_89T2
Pete_89T2's Avatar
What about the other alternator connector (field coil) - was that connected when you tested? If not, I'd test it again. If you're talking Amps here, 0.58A is A LOT of current - at that rate of current draw, you'll kill a battery pretty quickly.
To troubleshoot these kinds of problems, here's what I'd do:
1. Disconnect positive battery cable, and connect an ammeter in series between the battery + post and the + battery cable. Make sure it's an ammeter/digital multimeter that is rated to read up to at least 2 Amps without getting fried.
2. With every electrical gadget in the car turned off, read the current. If all is well, you should see a current draw of anywhere from 10~100 milliamps. This is a ballpark figure, and assumes you'll only have things like the clock, ECU, and a few other low current electrical loads drawing current when the key is off (e.g., radio memory presets, aftermarket gauges w/memory, etc.). This is normal.
3. If you read anything significantly higher than this (you were reading ~580mA), either something is on that shouldn't be on that you may have missed (e.g., glovebox light on when the door is closed?) or you have a short or defective circuit component somewhere. Start by looking closely at ALL the lights, and verifying that none are on.
4. If that test passes, then with the ammeter still connected, you'll want to remove fuses one-by-one in sequence, observing the ammeter each time you remove one. If the current draw drops significantly, you'll know you have a problem within the circuit whose fuse you just removed. Time to crack out the FSM/wiring diagrams and start troubleshooting that particular circuit.
Old 09-05-2012, 09:15 PM   #7
therex
bump started pulling fuses a couple weeks ago, it turned out to be my hazard fuse, no battery has died once again, no its my turn fuse. but now with both back in when the cars on acessory the sound of blinkers is nonstop but theyre not on... and nothing will turn the noise off
