Old 11-17-2008, 11:32 PM   #1
kagoshima
kagoshima is on a distinguished road
13b turbo SA22
Hello,
I want to swap a 13b series 6 into my SA22, single turbo will be used, or how hard is it to fit the twin turbo setup? In order to keep the original computer.
I need all the parts needed to make the engine fit
Please list whats needed (computer, exhaust manifold, mounts etc.) and price
Thankyou
Name: David Robertson. B.Int.Rel. MBA
Address: Japan, 899-4332 kirishima shi,
Kokubu Chuou 1, Choume 12-11-1
Email: robertson.david.campbell@gmail.com
Website: www.kagoshimaenglish.com
paypal: rotary.workshop@gmail.com
skype: kagoshima.english
ebay: http://shop.ebay.com.au/merchant/rotaryworkshop
kagoshima is offline   Reply With Quote
Old 11-18-2008, 12:01 AM   #2
TehMonkay
Originally Posted by kagoshima View Post
Hello,
Thankyou
Convert to single turbo, use a 1st gen front cover, gsl-se oil pan, special adapter to fit a 13b engine in there or a gsl-se subframe. You'll also need to drill and tap the front cover for a turbo oil drain, mount the motor like stock, use the 1st gen water pump and a nice upgraded radiator. Haltech standalone would be a good choice and you'll at least need to upgrade to a walbro 255lph efi fuel pump.
Then just have a custom exhaust made, among all of the other little bits and pieces. I reccomend at least upgrading to gsl-se brakes and getting some nice rubber, i think respeed also sells a kit to use T2 brakes and 5 lug wheels.
You'll need to upgrade the rear end to hold more than 300whp as well, a ford 8.8 or 9" rear end is a popular choice. Granny's speed shop has the conversion parts i do believe.
There is plenty of other things to do but i think i outlined most of the stuff specific to doing a big single swap into an sa.
Old 11-18-2008, 01:37 AM   #3
PercentSevenC
Custom User Title
PercentSevenC's Avatar
There are four ways to mount a 13B in a 12A chassis. All require a 12A or GSL-SE front cover (tapped for turbo oil return, in your case).
1. GSL-SE crossmember (probably difficult to come by if you're in Japan)
2. Racing Beat front mount bar
3. Slot the holes on your 12A crossmember and front mount bar each by 10mm
4. ReSpeed's adjustable crossmember (if you're planning on converting to rack and pinion steering)
Ditch the stock ECU. If your budget is tight, get a MegaSquirt. Then convert the twins to non-sequential or go single.
Like TehMonkay says, get some sticky tires and good brakes. I'd recommend ReSpeed's FC brake conversion. Don't forget a nice clutch/flywheel setup. Get an aluminum radiator and front-mount oil cooler and intercooler if you don't have them yet.
If you have an '84-85 (big flange, big bearing) rear end, you can just get the Moser axles from ReSpeed and it should hold as long as you're not making crazy power and launching on slicks. I'd be more concerned about the tranny. Upgrading to a TII unit would be a wise investment, and allows the use of 240mm cluch components.
One crucial step is an upgraded fuel system. Simply sticking a Walbro 255 in the stock system will not do. You'll need a surge tank at least. Tweakit sells them. Depending on your planned power level, and whether the car is a 12AT model or not, you may need larger lines as well.
Old 11-18-2008, 01:57 AM   #4
TehMonkay
Are SA tanks not baffled? I don't know too much about 1st gens. just learning on through.
I also forgot about the T2 tranny conversion, very good idea indeed.
Old 11-18-2008, 10:01 AM   #5
drewski86
Slow
drewski86 is on a distinguished road
What kind of budget do you have and what kind of power are you looking for? If you're unsure about power, what do you want to do with the car?
Physically getting the motor in the car is the easy part. You need a mount and a 1st Gen front cover tapped for oil return as stated above. Since you have the car and I'm assuming the front cover on the 12a, slot the holes on the 12a mount and pick up a GSL-SE oil pan for less than $20 used (I would suggest a oil pan baffle also for another ~$50) and now the motor is in the car. Or you can use the racing beat conversion mount($96), or do the Re-Speed cross member which will give you ability to use a mustang rack and pinion if you want($399-$850).
Then you have to either make a mount for either the REW tranny or a 2nd Gen TII tranny. You will also have to have the drive shaft modified with the correct yoke for the tranny. Expect to spend a couple hundred dollars here.
There are other things that need to be done(ecu, cooling, exhaust, clutch, etc.), but it all depends on your budget and power goals. Also the more work you can do yourself, the cheaper it will be.
drewski86 is offline   Reply With Quote
Old 11-18-2008, 11:55 AM   #6
PercentSevenC
Custom User Title
Not to a useful extent. If you're planning on boosting while cornering with less than, say, 1/3 tank, you need a surge tank. GSL-SE (and 12AT I assume) tanks have larger sumps, but they're still not even as big as that of an NA FC.
Old 11-18-2008, 10:59 PM   #7
whitey85mtu
whitey85mtu is on a distinguished road
you're all forgetting something very important, the FD uses a center mount system while the 13b-re or TII motors use a front motor mounting point. This is why it's much easier to put in a TII or 13b-re into a FB/SA.
whitey85mtu is offline   Reply With Quote
Old 11-18-2008, 11:23 PM   #8
PercentSevenC
Custom User Title
No, the FD uses a rear-mount setup. The FC uses a center-mount setup. That's why you need a first-gen style front cover in either case.
Edit: drewski86 is right about needing the GSL-SE oil pan. Forgot about that.
Old 11-19-2008, 01:24 PM   #9
Miata_mx5
Miata_mx5's Avatar
Miata_mx5 is on a distinguished road
Since you are in Japan, (if you can speak japanese) call R-Magic. They just recently swapped the guts of a series 6 FD into a yellow SA22C.
If you need a name and number, PM me.
Endless USA
My Livejournal Blog
Miata_mx5 is offline   Reply With Quote
Old 11-20-2008, 05:07 PM   #10
BigTeddy
BigTeddy is on a distinguished road
FD'S are rear mounted
FC are center mounted
SA/FB'S are front mounted hence the reason why he/she need the front cover to do the swap into a first gen chassis
One Turbo At A Time
BigTeddy is offline   Reply With Quote
Old 01-16-2009, 09:46 PM   #11
whitey85mtu
my bad
Old 01-27-2011, 05:22 AM   #12
dr50376272
dr50376272 is on a distinguished road
did it by myself, no troubles. sold
dr50376272 is offline   Reply With Quote
