Old 10-31-2010, 04:41 PM   #1
rx7mechusa
no no come on start plz?!
rx7mechusa's Avatar
rx7mechusa is on a distinguished road
Help Boosting issues 88 TII with S5 turbo
Hi i replaced the turbo on my S4 about 6 months ago have had no issues i used a s5 manifold and hotside and a garret T04B and made a hybrid turbo has worked beautifully untill about a week ago i cant boost above 3psi. Checked shaft play, all vac lines and caps, all inter-cooler connections and im at a loss. All emissions equipment has been removed and inter-cooler is a trust/greddy one that enters and exits on the same side to keep your P/S and A/C. Any recommendations or help would be greatly appreciated i think it may be the wastegate on the S5 hotside i can wiggle the mechanisim for the wastegate door. Again thanks for any help or recommendations
US ARMY-OH 58D(R) Helicopter Mechanic
Cars-
1988 10th AE
1993 Nissan Pathfinder (off road fun truck)
1999 GMC Suburban (10thAE personal transportation)
rx7mechusa is offline   Reply With Quote
Old 11-03-2010, 09:57 PM   #2
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
rxspeed7 is on a distinguished road
you need to pressure test the system and check for boost leaks/vacuum leaks. Also you may want to check to make sure that your wastegate is properly connected and hasn't come disconnected from the flapper.
Zack.
87 TII= High comp 13b-re,S360,Link G4 RX
I suppose you could orally BDC or even anally BDC someone? or be BDC'd in those two ways also
Many ways you can get BDC'd
rxspeed7 is offline   Reply With Quote
