Old 03-11-2010, 05:15 PM   #1
sen2two
KTEC
sen2two's Avatar
S5 omp
Im looking to remove it on a friends car. But as most of you already know, if the S5 electronic pump is removed, it will send the ecu into limp mode. And might not even idle in some cases. Anyone remove there OMP without an ecu upgrade?
if you did, how did you go about it? ideas, comments?
what I have:
What I had:
Old 03-11-2010, 05:34 PM   #2
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
why do you want to remove it exactly?
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 03-11-2010, 08:29 PM   #3
you take it off but leave it plugged in and secure it aside, then block off, run pre-mix, etc. there is no way to remove it completely without ecu modification
Old 03-11-2010, 09:26 PM   #4
Like Ferocious said, either tie it back still plugged into the harness, or get an Rtek with OMP delete.
Old 03-12-2010, 01:05 PM   #5
FC Zach
FC Zach's Avatar
You can remove it without the OMP in place, you'll just have to purchase one of these:
http://www.pocketlogger.com/?pid=rte...age=1&ecu=S5NA
Hope this helps. like DJ and Paul said, there is no other way than this.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
