Old 05-06-2012, 10:31 PM   #1
low compression
low compression is on a distinguished road
Default oil cooler placement
Just looking for any options or opinions on where to mount oil cooler in a vmount setup.
I have a few ideas but typically over analize everything before fabrication. It's getting nice
Out and I need to get going on finishing this. Thanks in advanced for any insight.
low compression is offline   Reply With Quote
Old 05-07-2012, 07:31 AM   #2
Oyvindjs
Oyvindjs is on a distinguished road
Default
keep it simple, stock locations?
edit: 2.nd gen forum, sorry.
What front bumper you have? do you have airflow through ducts on left and right hand side of centre, where the airflow to rad/IC is.
FD has stock location oil coolers on left and right hand side of this centre opening. doable on your FC? If so, gogo
Oyvindjs is offline   Reply With Quote
Old 05-07-2012, 05:01 PM   #3
Sharingan 19
Sharingan 19 is on a distinguished road
Default
just leave it in the stock location, mount your rad and IC accordingly and make your duct work accordingly.
Sharingan 19 is offline   Reply With Quote
Old 05-07-2012, 08:11 PM   #4
low compression
Default
Stock location is not an option. It's either duals in brake ducts
Which would be a lot of -10 hose or another location. I really don't want
To lose my brake ducts though. I was wondering if anyone mounted after
After radiator and any bad temps. I don't have a oil temp gauge now but
Maybe I should get one to monitor.
Old 05-07-2012, 10:46 PM   #5
Sharingan 19
Default
Well perhaps this thread should have been created as a poll instead of general inquiry.
What V-mount kit are you using?
After radiator = bad idea. Whats the point in going V-mount if you're still going to stack heat exchangers ?
Old 05-07-2012, 10:47 PM   #6
josh18_2k
Default
stick it on the radiator? my oil cooler is attached to the radiator with e-fan straps (those things that go throug the radiator fins)
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Ad Management by RedTyger
