-   Tires,Wheels,Suspension,Brakes (https://rotarycarclub.com/forumdisplay.php?f=77)
-   -   Need some help deciding on a summer / autocross / lapping tire! (https://rotarycarclub.com/showthread.php?t=7876)
Heeley 05-04-2009 11:47 AM
Hi guys,
I'm looking around at different summer tires, and I need a little advice. These are to go on my '93 R1.
I don't think i'm at the point where i want to be buying a set of dedicated track wheels/tires so I want something that's good on the street (liveable ride, good enough wear to get a couple of summers out of them), and going to be fun for autocross and maybe the odd lapping day. Here's what i'm looking at:
Falken Azenis RT615
Dunlop Direzza Z1 Star Spec
Nitto NT05 - I'd have to come across to the U.S. to pick these up as they are apparantly not available in Canada.
Budget choice: BFGoodrich G-Force Sport
If you own or have owned any of these tires, feedback on treadwear would be great. If i'm going to spend the $$$, i'd like them to hold up somewhat well to street driving. I do about 10,000 miles each year.
Mobius 05-04-2009 04:21 PM
The only tire's I've run out of that group are the RT615's.
I managed about 4000 km of hard driving before they were done, front and rear.
I did make it to one road course type event with them. Each run consisted of 6 consecutive laps (about one minute each). Laps one and two were slippery while the tires heated, three and four were quite nice, but by halfway through lap 5 (5 minutes or less of hard driving) they would get greasy.
P71 05-04-2009 04:49 PM
The G-Force Sports are not in the same category as the other 3.
I personally have the Azenis Rt615's on my RX-7 and I think they are wonderful for street driving and autocrossing. I have beaten similar cars on slicks with them.
The Nitto's are not worth it.
You may want to take a look at the Kuhmo ECSTA XS as well.
Heeley 05-04-2009 07:30 PM
I know the GForce sports aren't really in the same class of tire, but they would be more of a budget approach. I more or less threw them in there as an example of a harder compound street tire that would last on the street, but might still be a fun tire for autocross. I'm pretty sure they get used as a spec tire for various car control schools... i think the skip barber school uses them, but that might just be because they're predictable and cheap.
Good call on the Ecsta XS though. I'll have to check those out for the money
josh18_2k 05-04-2009 08:35 PM
star specs own the world at the moment.
the fastest street tire is probably advan neova, but they cost way too damn much
when in doubt, see what tire national champ STU/X guys run (they have a minimum 180 treadwear)
85rx-7gsl-se 05-04-2009 09:14 PM
Star Specs are badass. Just them and some Kosei K1's on his stock suspension Miata made a world of difference.
staticpat 05-05-2009 09:44 AM
Star specs!
Rogue_Wulff 05-05-2009 12:48 PM
The Z1 Star Spec is the quickest of the lot, when it comes to street tire classes (treadware 140 minimum). They aren't as widely available as the RT-615 (sizes).
The RT-615 has been around for a few years (2005 introduction) and has been the tire all others have been measured against, for grip and longevity.
The new Kumho XS seems to be in the same grip level, but lifespan and grip towards the end of life are still uncertain at this point, since it's such a new model.
The one thing that the RT-615 has going for it, while the intial grip isn't quite as high as some of the newer models, it doesn't seem to fall off as bad as some of the others.
They do take a bit longer to get fully up to temp than a few others, but in the end, the heat cycling doesn't affect them quite as bad.
When new, there are tires that are faster the the RT615, but towards the end, those same tires struggle to keep up with like-worn RT615's.
All street tires will get greasy when hot, that's unavoidable without killing overall lifespan.
The RT615 is also usually at the lower end of the pricing scale, making them a good choice for all-around use, particularly for those on a budget.
P71 05-05-2009 01:14 PM
Uh fellas, the Star Spec lost the latest GRM ST-Class tire test, badly. Even the old RT615's beat them.
The XS is the new fast king, the RE11 is right there as well, and the RS2/3 and the Rt615 are fighting for fastest for cheapest. The Rt is still the longest lasting and has best grip at end of lifespan. They're also cheap and come in 14" sizes, which most of the others don't.
Rogue_Wulff 05-05-2009 01:38 PM
Yeah, the RT615 having a 14 and 15 offering is certainly advantagous for us old schoolers. Many of the newer street tire class contenders totally ignore 14", and miss the mark on the 15" by offering a 195/55-15 instead of a 205/50-15. The 195/55 is a bit narrower and taller than the 205/50.
I just ordered a new set of wheels to fit my '83, and will be tossing a set of old RT615's on them to finish off. I may step up to actual r-comps, or stick with the RT615 for the next set of race rubber. The RT615 can be driven to/from events a little easier than R-comps. Too risky when it comes to punctures.
85rx-7gsl-se 05-05-2009 04:02 PM
Well I have heard nothing but good things outta the Star Specs. My buddy has RT-615s on his 240SX and they are alright to me, but nothing special. The Star Specs will pick up leaves fresh off the truck with no heat in them :D
Turbo II 05-05-2009 09:30 PM
Uh fellas, the Star Spec lost the latest GRM ST-Class tire test, badly. Even the old RT615's beat them. The XS is the new fast king, the RE11 is right there as well, and the RS2/3 and the Rt615 are fighting for fastest for cheapest. The Rt is still the longest lasting and has best grip at end of lifespan
I heard the same from a friend who was talking about it elsewhere. We're both running the RT615s.
GRM June 09 issue. The Kumho XS seems to be the king. The Kumhos were about 1 sec faster. 34.x versus the Falken at 35.x.
P71 05-05-2009 10:01 PM
Gotta read the article, when they re-ran the Rt's they went 34.x's as well ;)
Heeley 05-05-2009 10:08 PM
what's the lifespan going to be like if i run the rt615's on the street? approx. mileage?
Rogue_Wulff 05-05-2009 11:11 PM
Average life on the street can be anywhere from 3K to 20K. It all depends on how much fun you have in the meantime.
I know people that have gotten well over 100 autox runs out of a set, and others that are lucky to get 50. The power and weight of the car, along with driving habits, have a lot to do with how long they will last.
