285's on an FC (yah, i did it)
I'm sure all of you were wondering "whats the biggest tire i can stuff under the front of my FC, without using those godaweful 60mm tripoint flares?"
the answer - Corksport 30mm fenders. Unlike most fenders for the FC, CS fenders give an honest 30mm, maybe more (i didnt actually measure). Tein Flex coilovers, 2.5 degrees camber Drivers side: 18x9.5 +15 Enkei RPF1 285/30/18 Kumho V710 Passenger side: 17x9 +24 Bullitts 255/40/17 Advan A032-R the last v710 pic is with the tire compressed some (rolled up onto a curb). as you can see it tucks just fine. The tire will actually hit the frame rail before the fender. perfect fit! http://i131.photobucket.com/albums/p...C/DSC02845.jpg http://i131.photobucket.com/albums/p...C/DSC02842.jpg http://i131.photobucket.com/albums/p...C/DSC02844.jpg http://i131.photobucket.com/albums/p...C/DSC02841.jpg http://i131.photobucket.com/albums/p...C/DSC02846.jpg http://i131.photobucket.com/albums/p...C/DSC02847.jpg http://i131.photobucket.com/albums/p...C/DSC02849.jpg http://i131.photobucket.com/albums/p...C/DSC02850.jpg http://i131.photobucket.com/albums/p...C/DSC02851.jpg http://i131.photobucket.com/albums/p...C/DSC02852.jpg |
btw the 285s in the back (on the same wheel) require a serious fender pulling, or overfenders. with my rear ride height even with the front as pictured, it doesnt rub.
holy snapper that's a lot of meat!
So you have different wheels on each side of the car? Or did I misunderstand?
Very nice though! |
i only mounted one 18 for the pics. i dont drive like that.
17x9 +24 is a common setup for FC's (cuz mustang wheels are so cheap), and 255 is commonly advertized as the max tire for a fiberglass fender.
thought i'd kill 2 birds with 1 stone, and show how well the corksport fender covers a 255 mounted on 17x9 +24. |
i had my springs out today, so i thought i'd take more pics.
i jacked the tire up into the wheel well to see how much travel i really had. the corner of the tire is just barely touching the fender (i think). kinda hard to tell. should have passed a string over it or something... http://i131.photobucket.com/albums/p...C/DSC02857.jpg http://i131.photobucket.com/albums/p...C/DSC02853.jpg http://i131.photobucket.com/albums/p...C/DSC02854.jpg http://i131.photobucket.com/albums/p...C/DSC02855.jpg |
That is great fitment! I might have to pick up a set of these when I decide to go wider...
i run Kuhmo V700 285/35-17's in the front and Kuhmo V700 335/35-17's in the rear on some Simmons of Austraila Alta's. by the way the Enkei RPF1's look great
update-
the "slammed" pics above show where the tire sits with the damper fully compressed. what it doesnt show is if it will rub while cornering.. at the last autocross i put zip ties on the dampers and ran my race. no rubbing at all, and when i checked the ties they were squished up into the camber plates (full travel). it was a really bumpy course... in short- fitment works for cornering. |
| All times are GMT -5. The time now is 03:53 PM. |
