-   KG Parts (https://rotarycarclub.com/forumdisplay.php?f=124)
-   -   High Imp 1600cc Injectors (https://rotarycarclub.com/showthread.php?t=6658)
KGParts 02-16-2009 10:13 PM
For those that do not already know... production has stopped on the standard 1600cc injectors, and they may not be returning to the market.
However...
We should have HIGH imp 1600cc injectors available by the beginning of next month. Hopefully this will solve a lot of install issues and they will have a much better response time as well as overall performance than the standard Bosch 1600's.
Some are in hand ready to go with balance of order arriving shortly. You wont be able to get these anywhere else as they were a limited run with a long story behind them. We are acquiring all we can as these supposedly are the only ones in existance, they are not an everyday injector that was modifed as some other higher flowing injectors hitting the market recently are.
We are trying to come up with a solution for those who have already purchased our rails in the past so they will not require a new rail as these are a different body than the standard Bosch the other rails were designed to run.
Stand by :driving:
KGParts 02-17-2009 06:47 AM
**edit*
ehron 03-18-2009 05:21 PM
Any update on this?
KGParts 04-02-2009 06:31 AM
have been busy and have not had much of a chance to move forward on this, but it is not an abandoned project.
