FS/FT misc s4 and s5 parts, looking for other misc s4/s5 parts
I have the following for sale, all prices are without shipping the parts are located in Michigan (dog not included):
S5 EFI harness - 35 S5 N350 map sensor - 15 S5 6 port LIM - 15 S5 OMP w/ only 2 oil lines - 25 S5 flywheel (I can resurface it for you) - 60 with resurfacing S4 OMP w all oil lines - 35 S4 rear counterweight - 80 S4 oil pan w/ working oil level sender - 20 http://img155.imageshack.us/img155/4023/dscn0808qv7.jpg I'm going megasquirt so I need to get all the s4 EFI out of my engine bay, if there is something you need there let me know and I can take it out for you. make offer on the following parts below: S4 ecu S4 EFI harness w/o rat nest connectors S4 MAP S4 vane airflow sensor anything else you can think of (except the coils) but I do need the following parts and will be willing to trade: s5 rear counterweight s5 OMP block off plate oil injector plugs for block and manifolds oil baffle plate S5 upper fuel rail pair of S5 injectors S5 BAC valve I am paypal verified and my email/paypal is fidelity101@gmail.com all parts are NA and I am only looking for NA parts |
I also have a working s4 air pump for 10 + shipping
I have the S5 upper fuel rail, injectors and BAC.
i might want to discuss the S4 counterweight depending on what rotors i wind up with.
LIM and air pump are spoken for... at the recycler I might do without the BAC because its not going to be an everyday car. |
I may also want the UIM (s4)
let me know within the next week because I will be taking 2 large boxes of misc AL parts to the recyclers. Or if I should set one UIM aside.
Okay I just picked up S5 BAC, Alternator, upper fuel rail w/ injectors/pressure regulator, TB with TPS attached. so I no longer need those
but I still need a rear counterweight from an S5 |
WTB Pineapple racing 6pt inserts and S5 NA LIM.
got LIM
still looking for 6pt inserts and S5/S6 rear counterweight |
| All times are GMT -5. The time now is 02:15 PM. |
