Post your engine bay pics
every forum needs onoe of these threads..
http://i34.photobucket.com/albums/d1...E/DSC00140.jpg i just finished installing the front strut brace, boost controller, and launch control yesterday. the brace is not the best fit, i had to lose the upper A/C line, but i wnat to keep A/C on this car so i will have to make a custom line to fit. the fan needed trimming also, and both the fuseblock and boost sensor brackets had to be moved |
This was taken right after I installed the TII engine, during shakedown.
Not much has changed except for a Apexi Twin Chamber, and the fan shroud is back on. http://lh3.ggpht.com/_OFjbTkyhkOs/R7...0/DSC00637.JPG |
http://lh3.ggpht.com/_DOIP7bvsJCI/ST...gine-front.jpg
I changed water pump and painted it and the housing as well as relocated my autometer water sensor to the back all at the same time and it looks much cheaner... too bad it has low oil pressure |
i need to get some new pics. these are kinda old.
http://i99.photobucket.com/albums/l2...II/engine3.jpg http://i99.photobucket.com/albums/l2...II/engine2.jpg http://i99.photobucket.com/albums/l2...II/engine4.jpg |
jamin, no front mount yet?
I cannot get over how odd that diesel looks in an FC. Although it strangely looks like it was meant to be there.
did you know that your left front strut is missing? you may want to get that looked at. :)
one of these things is not like the other :willy_nilly:
http://i131.photobucket.com/albums/p...C/DSC02462.jpg |
2 Attachment(s)
heres mine
Need moar!
| All times are GMT -5. The time now is 05:05 AM. |
