-   Rotary Tech - General Rotary Engine related tech section.. (https://rotarycarclub.com/forumdisplay.php?f=131)
-   -   Where should i put the muffler in the system? (https://rotarycarclub.com/showthread.php?t=4137)
Whizbang 09-16-2008 01:29 PM
i am thinking at the end, since it may help eliminate the "annoying" tin sounds from the exhaust. but my setup would be easier to run it in the middle before the rear suspension.
Whizbang 09-19-2008 08:10 AM
So i just put it in the middle, about where the stock cat would go. The magnaflow i used has real good dimensions so clearance to the ground is still very good.
Sound wise? Much much better. Im very please. I still need a new exhaust gasket for the DP to the the rest of the exhaust. Seems to have blown out...
PercentSevenC 09-25-2008 02:39 PM
Having the exhaust go through the muffler sooner in the system is probably better for reducing metallic noise, I'd imagine.
Is this for your FB? Which Magnaflow did you use? I'd like to put something there in a system I'm planning.
Whizbang 09-25-2008 02:59 PM
this was for my TUrbo II. if you look in the thread for it in the projects section youll see a picture of it. Its a Magnaflow, not sure which model exactly.
