Vacuum Diagrams
http://i21.photobucket.com/albums/b2...e_diagram2.jpg
http://i21.photobucket.com/albums/b2...nglevachos.jpg I don't take credit for these diagrams. Just posted them on my photobucket, and posted them here for archive purpose. |
non-sequential
http://i182.photobucket.com/albums/x...93/non-seq.jpg simplified stock twins http://i182.photobucket.com/albums/x...simplified.jpg |
Could those be MORE complicated?
About the stock vaccum line configuration I wonder, how many hours of training it took for each employee dealing with vacuum line hook up at the Hiroshima plant?
It does take a while to figure out if you are working on your car.
I still don't like how it's called "simplified seq." All it is, is the seq. system with basically all the emissions removed, it really doesn't simplify the seq./turbo vacuum hoses at all. |
Yay, an easier single turbo diagram *right click and saves* Thank you ^_^
so, anyone know where to get an FC version? TII specifically. I searched and haven't been able to find anything yet.
i have been braking my head trying to figure out a better way to relay simplify the vacuum diagram. i personally believe that Mazda`s engineers did a very good job designing the the vacuum system and its very impressive how it works.on the lighter side i also believe that they had a little too much coffee in the process.i was just discussing the importance of the vacuum chambers in the other forums and as of yet i haven't been able to figure out a real reason why from what i can tell the turbo control solenoid valve is that intricate and sensitive that you need two solenoids (h and f) for charge and relieve along with a vacuum chamber box for it to maintain a certain amount of pressure.how many psi does that closed system needs to hold with in that loop for that turbo control solenoid to work? it works only on vacuum i don't see why it was 3 intake connections that can only work on vacuum just to control the lower actuator.
hey for the simplified seq set up- are block off plates needed? the only one i have is the acv block off plate at the moment
1 Attachment(s)
hey where does this line connect to? from the original diagram it connects to the pressure chamber but in the simplified the pressure chamber is moved... so should i just block off this line?
Wanted to post my plotter size diagram http://www.filedropper.com/fullpagephoto it's
40x28 here's how it looks http://i23.photobucket.com/albums/b3...r/IMG_0038.jpg |
You should frame that
| All times are GMT -5. The time now is 05:06 AM. |
