S4 Wastegate porting
Bryan
I just acquired a hybrid turbo. It has an S4 turbine housing; I need to get the wastegate ported. I don't have the hook up at the 2nd Maintenance Battalion machine shop like I used to. Can I ship the turbine housing by itself to you, and how much would it cost me? Also, what would you estimate the turn around time to be? Thanks Jason |
$225 for the turbine housing to be machined, and the stainless valve assembly to be installed. The port is around 33mm right off the machine, but I can easily hand port that to around 35mm.
Bryan@BNR 205 640 1193 |
| All times are GMT -5. The time now is 08:52 AM. |
