FS: S4 T2 rotors and housings
Everything here came from a strong running engine that had an oil seal problem. Cold compression numbers were 105 all around on the front and 95 all around on the rear.
My paypal address is: stanello@gmail.com I've got a set of S4 T2 rotors that are clean, with useable bearings. They are a "D" and an "E" weight $125 Shipped each or $200 Shipped for both. http://i89.photobucket.com/albums/k2.../daddedaef.jpg I also have a set of S4 T2 housings in good shape. Housing 1 is $150 Shipped Housing 2 is $200 Shipped Or both for $300 Shipped http://i89.photobucket.com/albums/k2...ubgonlk001.jpg Housing 1: Has normal S4 edge wear, and a bit of chrome flaking. Also has a moderate amount of light marks above the trailing plug hole. These marks are not deep, and you cannot catch a fingernail on them. http://i89.photobucket.com/albums/k2...llo/njk001.jpg http://i89.photobucket.com/albums/k2...llo/njk002.jpg http://i89.photobucket.com/albums/k2...ubgonlk002.jpg Housing 2: Has normal S4 edge wear and no chrome flaking. Has much less marks over the trailing plug hole and they are very light. You cannot catch a fingernail on them. This is one of the better used S4 housings I've came across. http://i89.photobucket.com/albums/k2...llo/njk003.jpg http://i89.photobucket.com/albums/k2...llo/njk004.jpg http://i89.photobucket.com/albums/k2...ubgonlk005.jpg |
Rotors sold
| All times are GMT -5. The time now is 05:08 PM. |
