Pete's Big S5T2 Leftover Parts Sale
5 Attachment(s)
I recently upgraded my ECU, wiring, sensors, fuel system & other bits of my FC and have a bunch of leftover OEM parts and some aftermarket parts for sale.
All parts are in great condition, were well cared for & fully functional when I removed them, and all were from my '89T2 (S5T2). Some of these parts will work on other years/flavors of FCs, but it's on you to verify applicability before buying. Pictures of each item are included in this ad. Unless otherwise noted, I have one (1) of each item listed for sale, and if it isn't listed here, I probably don't have it or it's not for sale. Terms: (1) Unless otherwise noted below, prices listed are firm, and do not include shipping, but I'll ship anywhere at buyer's expense. Everything is located in Elkton, MD (21921) for local pick-ups. (2) Payment via PayPal or cash. Parts Listing: - SOLD ECU/Engine Wiring Harness (Mazda # N370-18-05ZD) - $500. This harness was purchased new only a few years ago from Mazda, and is in excellent shape with no crispy/hacked wires or corrosion anywhere. Can't buy these new from Mazda anymore, and good luck finding a used one in this good a condition. Must have if you intend to keep your FC running on a stock ECU or Rtek chipped ECU - Pair (2x) Bosch 720cc Fuel Injectors - Drop in fitment to the stock S5T2 fuel rails, $100. Price includes the wiring pigtail adapters for free. - S5T2 Air Flow Meter (AFM) - $80 - SOLD S5T2 Stock Turbo Inlet Duct - $50. This one is just a few years old, great condition. No cracks, rubber like new & still pliable. - S5T2 OEM Primary & Secondary Fuel Rails - $70 for both rails, $40 each if someone wants just one or the other. - S5T2 Turbo Oil Drain Pipe ?€“ This is the larger pipe assembly that returns oil from bottom of the turbo back to the front cover. NLA from Mazda, $50. - Pro-Sport "Performance Series" Oil Pressure gauge - $30. Was in working order when removed. This is the dual color (White/Red) gauge that matches well with the stock red gauge lighting; 270* sweep electrical gauges. Includes the sender unit. - S5T2 Stock Fan Clutch - $60 Clutch is only a year old; will throw in the fan for free if wanted, but that will drive up shipping cost (bigger box) - S5T2 Stock Plastic Thermostat Housing/Neck - $25 OBO - SOLD Crank Angle Sensor (CAS) - $50 OBO - Leading Coils - $40 OBO - Trailing Coils - $40 OBO - S5T2 Stock Intercooler to Charge Pipe Rubber Elbow - $25 OBO - S5T2 Air Filter Box w/K&N panel filter - $40.00 OBO - S5T2 Air Pump (aka smog pump) - $50 OBO - S5T2 Air Control Valve (ACV) - $40 OBO - S5T2 Water Pump - $25 OBO - S5T2 Anti-Lock Brake System (ABS) Electronic Control Unit - $50 OBO - Water Pump Housing - $30 OBO; This one's not from my car, it's from an S4T2 - K&N oval cone air filter that fits directly on the S5T2 AFM - $20 OBO - OMP Block-Off Plate - $10 OBO - SOLD S5T2 Stock Turbo Boost Control Solenoid - $20 OBO - S5T2 Misc. Solenoid Valves from the rat's nest - $20 OBO for all (3x - Gray, Green & Orange solenoids). |
5 Attachment(s)
Well, RCC only allows 5 pictures per post, so pictures of the the rest of the stuff will be in this and the following replies... Click the thumbnails to show full size.
5 Attachment(s)
Next 5 pictures...
5 Attachment(s)
Next batch of 5 pictures...
5 Attachment(s)
3 Attachment(s)
Last batch of pictures...
Pete I'm interested in the Oil Temp and Water Temp gauges. I need to check to see if they will match my OP gauge first though. I can't remember which one I bought. Where you using the temp sensor that you have to cut the radiator hose up?
Alternatively, some FCs have an unused spot on the back of the WP housing where you can drill & tap for the 1/8"NPT sensor. BTW, here's a link to the Prosport site for the same series gauges I'm selling so you can compare to your existing oil pressure gauge - http://prosportgauges.com/amber_whit...ce_gauges.aspx |
Pete... my bad I forgot to check my gauge last night. I'll check today.
Ok Pete.... how much for the OT and WT shipped to 37130?
Got the gauges Pete! Thanks!
Bump - stuff is still up for sale
Bump - Someone buy this stuff already, need gas & beer $ for DGRR! :D
Wiring harness is sold, rest of the stuff listed is still available.
| All times are GMT -5. The time now is 08:27 AM. |
