New Rx7 owner
Hello Everyone ,
i've recently bought a 1993 rx7 , and i want to replace the front bumper with the 99' spec , i found a polyurethane bumper on eBay , should i buy it ? is it good ? - is it better than fibreglass ? - better then plastic ? thanks . |
1 Attachment(s)
Fiberglass breaks easy and is easy to repair .Plastic breaks and needs special equipment to weld for repair. I pick poly ,hard to break ,also needs special equipment to weld .
Welcome to the forum.
You're likely going to want a body shop involved while fitting any aftermarket (non OEM) bumper as they tend to need massaging a bit. Frankly there isn't that much information being provided on the specific bumper you're looking at, so it will be difficult to give suggestions on whether or not you should buy it and/or the quality of the product itself. More information would be needed. How about a bit more info on yourself and your car though? Pictures, location, background, etc., etc., etc. Cheers, Levi |
Welcome!
| All times are GMT -5. The time now is 11:18 AM. |
