Anyone know where this vaccum port goes to?
1 Attachment(s)
When playing around in the engine bay the other day I noticed this vaccum port down by the 5th/6th port actuators that wasnt hooked up to anything. The picture kinda sucks but if anyone knows what it should be hooked up to could you please elighten me?
Looks like the pressure tube to actuate your secondaries. It should be connected to a fitting in your exhaust pipe if it's an S4. S5 uses pressure from the air pump. I'm unsure where that is hooked at.
Hey guys, this is just a reminder that you're posting in the CLASSIFIED subsection.
I'm sure you intended to post in the TECH, 2nd Gen subsection...? :) I don't have authority in here, so I can't move this automatically. :( If this is the case, you can contact someone who has the authority, or WankelsRevenge can move his own Classifieds thread that he / she started - on the (forum tool?) bar => Thread Tools | Move Thread ... -Ted |
Gracias sir. I would of never noticed this if you hadnt said something.
it is to activate the auxiliary ports through a connection to the split air pipe going down to the main cat.
| All times are GMT -5. The time now is 03:55 PM. |
