Remove airbag=no horn
I removed my airbag recently and was trying to figure out what I removed that would make the horn not work. All I removed was the passenger side airbag itself, and the impact sensor and harness from the engine bay. With some guidance from a couple fellow FD owners, I simply cut the connector off my airbag harness, spliced the wires together, and plugged it back in. Works like a charm.
http://i44.photobucket.com/albums/f9...ps0ef18368.jpg http://i44.photobucket.com/albums/f9...ps1c741f8e.jpg http://i44.photobucket.com/albums/f9...psf990ac3e.jpg http://i44.photobucket.com/albums/f9...ps542baa58.jpg Just wanted to put this out there just in case someone else does the same thing and has the same problem. |
| All times are GMT -5. The time now is 11:20 AM. |
