-   Old School Rotary (Pre-1979) (https://rotarycarclub.com/forumdisplay.php?f=39)
-   -   Rx3 strut top on Rx2? (https://rotarycarclub.com/showthread.php?t=17380)
Whizbang 05-27-2013 11:33 AM
is the top mount three bolt pattern for the struts the same as an Rx2 as it is for an Rx3?
is the rx3 even a three bolt pattern? looking for options for camber plates for the Rx2, especially with pillowball.
TOOL 06-21-2013 07:08 AM
RX3 is 3 bolt, but not in the same orientation.
You will struggle to find adjustable top mounts as the hole in the top if the RX2 strut is very small and limits the adjustment.
There is a guy called Tony on Trademe in NZ who makes adjustable top mounts for RX2 but you will have to run them with coilovers as they don't work with the original diameter springs or top hat.
