1990 Black S5 Turbo Convertible
For sale is my turbo convertible FC Rx7. Located in Nashville, TN. I've decided to take a different path and would like this nice example of an FC to not be parted out. The main points are that it has just over 89,500 miles, has a turbo (Turbo II) engine and transmission, Full standalone Haltech Sprint RE ECU, ugraded fuel system, black w/ black interior, black leather Rx-8 seats, full Racing Beat exhaust, KYB AGX w/ ground control springs, TII replica lip, newer tires, and the top is in great shape for original (8/10). It is currently the Ride of the Month!
Dyno tested at 242hp/250tq on a Dyno Dynamics (reads lower than other dynos) with current setup (stock turbo). 13-14 psi at peak tq, with 8psi at redline due to limitations of stock turbo. https://lh4.googleusercontent.com/-f...5/IMAG1017.jpg https://lh3.googleusercontent.com/-4...s1035/IMAG1001 https://lh4.googleusercontent.com/-9...o+242.6whp.jpg The Good: -89k miles rust free chassis -Original Black paint in 8/10 condition -Original top in 8/10 condition -Complete interior in 8/10 condition -Black leather Rx-8 seats -Driver side seat is power adjustable (passenger is manual as in all Rx8s) -Seats have seat heaters but they are not wired to the car -The rear supension/subframe is in great shape, no broken mounts -No suspension clunks over bumps or while turning -Good tires 225/50-15 Kumho AST (75-80% tread) -Tinted sidemarkers and turn signals -Finishline option large center armrest -800CCA Autocraft Titanium battery The Bad (being as detailed and honest as possible, most sound worse than they are): -Agressive clutch by design is not the smoothest in operation -Several light scratches -Door ding on the driver's door and scratch on passenger door. Overall in good shape. -3-4 Small hood dents typical of vehicle of this age -Upwards dent in hood due to BOV hitting hood under boost (c-clip install error). Cracked paint in that one spot. -Airbag light is currently on due to missing right front corner airbag sensor -The front bumper has been modified to fit a FMIC. TII lip makes this less noticable. -There is a crack in the driver side taillight. It is on a corner and not very noticable. -There is the start of a tear on the top, but it is not "open" can can be patched from the inside. There are also tears where there is tension on the top when down near the drain pockets. These seem to only minimally effect drain function. -The one time I have had the car out during a heavy rain it leaked where the top, windshield, and window meet. The seals are in good shape but the glue holding them down is weak. I believe it to be repairable. It was a very heavy rain with it stationary in a parking lot. -Passenger window switch on driver's side works intermittently. Driver side switch and passenger switch (passenger side) work properly. Pics can be provided for all upon request. Upgrades: Haltech Sprint RE standalone ECU with new harness using Deutsch connectors for CAS and Coil packs New factory TPS Injector Dynamics 1000cc injectors in both primary and secondary locations Parallel fuel line setup in engine bay with AN fittings for better flow (overall fuel setup can support 400whp) Aeromotive FPR New Reman FD Rx7 alternator with Japan2LA Dual belt pulley Turbo Transmission and Driveshaft 4-puck sprung ACT clutch with upgraded Pressure Plate Front Mount Intercooler Synchronic BOV Rx-8 seats Full Racing beat turbo exhaust (3", single piece DP and presilencer) KYB AGX shocks Ground Control coilovers (375lb front, 250lb rear) Ground Control rear camber bar Denso FD/Supra fuel pump Autometer Boost gauge, and water temp, oil pressure gauge, and wideband in rare "1fastT2" gauge pod Innovate Wideband with gauge Hawk HPS pads Replica TII lip Relocated battery New power/alternator/starter/ground wires Clean TN title. The chassis is firm, the interior is great, the exterior good with only the slightest hints of fading. The exhaust is complete and arguably the best sounding exhaust for a street Rx7. Overall this FC is in very good shape. I will be glad to take any detailed pictures or answer any questions. Test drives only for serious inquiries. $5000 firm. https://lh4.googleusercontent.com/-n...0/IMAG0169.jpg https://lh5.googleusercontent.com/-J...0/IMAG0166.jpg https://lh3.googleusercontent.com/-M...0/IMAG0165.jpg https://lh6.googleusercontent.com/-p...0/IMG_1025.JPG https://lh5.googleusercontent.com/-b...0/IMAG0108.jpg https://lh6.googleusercontent.com/-d...0/IMAG0096.jpg |
Fuel system with 4x ID1000 injectors, Pushlock hose, AN fittings, and Aeromotive FPR (about 1 yr old)
https://lh5.googleusercontent.com/-P...320_194543.jpg Sprint RE https://lh4.googleusercontent.com/-T...Cxk/s771/2.jpg https://lh3.googleusercontent.com/-H...VI/s771/10.jpg https://lh6.googleusercontent.com/-F...1c/s771/14.jpg https://lh3.googleusercontent.com/-o...pM/s771/16.jpg Clutch disc https://lh4.googleusercontent.com/-H...64/%5BUNSET%5D |
Can't believe your selling it! Good luck with the sale. It is a very nice Vert!
1 Attachment(s)
Attached is a VIN report I did a while back. Should have no change other than re-registrations.
Feel free to pull a carfax if desired. |
A few more additions to add:
Good: Shifter has a 5-speed Rx-8 knob Shifter has been shortened about 1" and rethreaded for better feel (not a short shifter) All shifter bushings have been replaced: -top and bottom cup bushings and springs -groove bushing -lower ball bushing (custom made Delrin piece made by a forum member) makes big difference! OE piece requires tailshaft removal, this piece slides in like s4 bushing Not Good: -A/C is not functional. Car was bought without equipment, so I do not have the components to reinstall. Convertibles don't need A/C ;) -Wiper switch has typical relay problem. Works on higher speed, does not work intermittently, will need new switch or relays replaced. |
cold start and walkaround vid showing small dents/dings.
Detailed car last night. Walked out this morning to it covered in pollen. Thats what I get for leaving it out of garage. :icon_no2: |
This video is being processed. Try again later.
Sold!
NOOOooooo
| All times are GMT -5. The time now is 07:09 AM. |
