New NGK BUR7EQ / BUR9EQ Spark Plugs
This might be old news for some of you...
I never realized that NGK redesigned these plugs recently? It looks like there's a really minor difference in "reach" spec... Also, the center electrode matterial has been changed? The BIG difference is the with the "semi surface" tip to a regular, single electrode tip? These what Mazda recommends for the RX-8 now? -Ted |
Haven't noticed a thing, I'm getting set of 7s soon. I'll check to see if they're any different from the last set.
That's if I get a newly manufactured set of course.
Are you saying they look like this?
http://www.ngksparkplugs.com/images/tip/NGK3514-2.jpg That is a picture of the RX-8 spec Leading Plug (RE7C-L). If so, that's weird since their catalog shows the old (ie: 'normal') style plug. |
If that is the case, NGK is using the same picture for both leading and trailing plugs.
I have a set of NGK RX-8 plugs in the garage, but I'm too lazy to go check :-) |
I just bought two sets of BUR9EQ's and a set of whatever the colder plug for the 8 is..... lemme go check and see....
I just ordered a set of NGK BUR7EQP/BUR9EQP's from Rockauto, I'll let you know what they look like when I get them.
That's where I got mine from.... Oddly enough, they are the cheapest....
RX8 ones look like RX8 plugs, BUR9EQ's look like they always have :dunno:
Old NGK BUR7EQ PN#3559
http://www.summitracing.com/parts/ngk-3559 Quote:
New NGK BUR7EQ PN#6917 http://www.summitracing.com/parts/ngk-6917 Quote:
Note between the two... * Material - Nickel Alloy versus Copper * Spark Plug Reach - 0.750 in. versus 21.5mm * Ground Strap Quantity - Four versus One -Ted |
Old NGK BUR9EQ PN#5483
http://www.summitracing.com/parts/ngk-5483 Quote:
New NGK BUR9EQ PN#5777 http://www.summitracing.com/parts/ngk-5777 Quote:
It looks like the 9's haven't changed as much as the 7's? The reach spec has changed... Better for us? BTW, the "old" 7's and 9's are listed "N/A" from Summit. -Ted |
That's odd.
This link has a generic image: "Old NGK BUR9EQ PN#5483" http://www.summitracing.com/parts/ngk-5483 |
I would trust things from the manufacturer more than from Summit, they could've messed a few things up when they copied and pasted the info.... I dunno, I'm kinda want to see a new one next to an old one....
I just got mine from rock auto yesterday. No changes from the old style, but the box had the same part # (5255 and 4764) as the old style too, so no changes expected.
| All times are GMT -5. The time now is 11:19 AM. |
