-   Introduce yourself!! (https://rotarycarclub.com/forumdisplay.php?f=64)
-   -   New member with an RX-7 (https://rotarycarclub.com/showthread.php?t=16467)
irbyjr 10-20-2012 03:46 PM
Hello all. I am Irbyjr, have had a '83 RX-7 GSL since 1984. I have an item or two I'd like some advice on, and will submit a new post for that.
Thanks
GySgtFrank 10-20-2012 05:49 PM
You are a tease aren't you? Info? You, car, personal pecadillos? Welcome to the dark side, beware the FB naysayers, they know not whereof they speak.
Viperx7 10-20-2012 08:24 PM
Welcome to the Club.
93rx7r1 10-20-2012 08:59 PM
Welcome to the club. Post some pics of your rx7 when you can!!
irbyjr 10-21-2012 11:50 AM
My '83 RX-7 GSL has an oil leak that contacts the exhaust manifold. My mechanic buddy thinks it is from the timing cover, but he can't find the gasket or whatever to fix the problem. Any leads for help??
No pictures yet but later I hope
THanks
Irbyjr
GySgtFrank 10-21-2012 03:30 PM
Do you mean the front cover? MazdaTrix carries a lot of small parts. Check your oil injection lines and pump for leaks, they run along that side. I had a leak there before. If you don't know where they're at download the FSM (Service Manual) from
http://foxed.ca/foxed/index.php?page=rx7manual
The manual will help in trying to track down the leak and many other things. A little hard to diagnose without seeing it.
irbyjr 10-21-2012 07:31 PM
Thanks a bunch, we'll try.
Irbyjr
cosmicbang 11-06-2012 06:58 PM
Any progress finding the source of the oil leak?
irbyjr 11-06-2012 08:42 PM
My mechanic friend thinks the leak is coming from the timing cover and/or the oil pan. Gaskets should be cheap for this, but labor appears to be way up there. I am trying to decide what to do (or what NOT to do).
Comments, suggestions?
Thanks,
Irbyjr
Rot 11-07-2012 12:48 AM
Welcome to the club! Check your oil metering lines sealing washers, sometimes they leak check with engine running, hope you'll find it!
