-   -   FD gauge dash: how the hell this thing works? (https://rotarycarclub.com/showthread.php?t=1574)
-xlr8planet- 04-06-2008 10:29 PM
Im halfway on the schematics.
Could someone PLEASE sumarize for me what works using the cars ECU and what works just out of a sender?
pleeeeease
mazpower 04-07-2008 12:15 PM
Oil pressure, coolant temp, and fuel level are all sending unit driven gauges. The speedometer, tach, oil level light, coolant level light, and all other lights are driven by the ECU INSIDE the gauge cluster.
-xlr8planet- 04-07-2008 02:04 PM
There´s an ecu inside the gauge cluster? Besides the load ecu and the main ecuż?
from the schematics my conclusion was:
Oil pressure, coolant temp, and fuel level = analog signals, easy to do
Tach = signal from coil
Speedometer = signal from gearbox, goes to the ecu and then to the dash
Pics... easy to read schematics or idiot notes would be great
I need a "GAUGE CLUSTER FOR DUMMIES" kinda thing,...
mazpower 04-07-2008 03:12 PM
What exactly are you trying to do?
-xlr8planet- 04-07-2008 03:39 PM
Im installing an FD interior in an FB :D
mazpower 04-07-2008 05:37 PM
Ahh I see.
What you need to do first, is get the cluster to power up. Here's the FSM schematic for the cluster (you may have this already):
http://www.rotaryheads.com/PDF/3rd_g...ng_Diagram.pdf
Go to page 46.
The connections are pretty self-explanatory. The tach connection is either the blue/yellow (4C) or yellow/blue (3F) wire, I can't remember for sure. The oil level light won't come on unless the wire is grounded, the coolant level light (and buzzer) WILL come on unless its grounded. If you are going to disable that, ground it to one of the ground wires in the cluster.
The ABS & Air Bag lights are going to come on. Best thing to do is pull the bulbs. When you pull the bulb for the air bag light, the cluster is going to make a faint series of beeps when you turn it on. It will take about 5 seconds or so for the beeps to stop and it will do this every time you power up the cluster. After a while you stop noticing it...its not like a coolant buzzer. :)
-xlr8planet- 04-07-2008 07:53 PM
Thanks man. :) I really appreciate it
I still need the dash harness, that will simplify my life...
-xlr8planet- 04-08-2008 09:38 PM
At least Im making progress
I´ve identified several things and acording to the 94 FSM and the 81 FSM the water temp sensor output is the same :)
So I just have to give that gauge 12v + ground + signal and I already identified what conector is what
-xlr8planet- 04-08-2008 10:47 PM
http://img221.imageshack.us/img221/4...ntgaugelq7.jpg
-xlr8planet- 04-09-2008 08:48 AM
http://img206.imageshack.us/img206/600/fbvaluesdo2.jpg
FB values
-xlr8planet- 04-09-2008 09:01 AM
http://img260.imageshack.us/img260/2157/fdvaluesrj7.jpg
