-   Rotary Tech - General Rotary Engine related tech section.. (https://rotarycarclub.com/forumdisplay.php?f=131)
-   -   Cereamic Coating Intake Manifolds? (https://rotarycarclub.com/showthread.php?t=15105)
WankelsRevenge 12-16-2011 12:58 AM
So pretty much everyone out there knows the benefits of cereamic coating diffrent parts of the exhaust systen, but what about on the intake manifolds? I would think this could help alot by keeping the intake temps lower. Has anyone tried this before, or would it be pretty useless?
Ryan
speedjunkie 12-16-2011 05:46 AM
I have my LIM ceramic coated since it's right there next to the turbo, but I couldn't tell you if it helped since I don't have any sensors in that part LOL.
Raksj04 12-16-2011 08:59 AM
Wouldn't your Air Inlet temp sensor read a lower temp if it did work?
Fendamonky 12-16-2011 09:24 AM
I had both my UIM and LIM ceramic (and teflon) coated when I had them extrude honed.
I honestly don't have any specific comparisons to say whether it's colder or not since I had it done when I got a rebuild, and swapped from twins to a single.
That being said, I have noticed that the UIM typically feels much cooler to the touch after I stop.
I think there are a lot of factors that go into this though... I've also got ceramic coating on my turbo/DP, I have Turblown's inconel heat shield for the LIM, I'm spraying water/meth starting progressively from a lower boost, etc., etc.
I'd say that if you ONLY ceramic coated your LIM/UIM than it probably wouldn't really make that much of a difference, as heat would be seeping in from other areas. However if you do it in part with other precautions you'll def probably notice it's effectiveness.
speedjunkie 12-16-2011 03:13 PM
No, because the sensor is mounted in the UIM and the LIM is what's ceramic coated, right before going into the engine.
Agreed. I only have mine ceramic coated but I think I'd rather have the heat shield. Maybe the ceramic coating is helping a lot, but I'm not sure. Especially since all my stuff is done in black HAHA. I may look into getting a heat shield but the ones at Turblown I'm not sure will work because of how close my turbo sits, or maybe it's another reason, I can't remember now haha. I know there's a reason I haven't bought one though. Do those fit with a GZ LIM?
Force13b 12-16-2011 03:24 PM
You could heat tape over the ceramic coat. I heat taped the under side of my UIM. I haven't done my LIM because i don't want to pull the turbos to get it off yet. When i go single i'm sure i'll ceramic and tape the outside of the LIM.
http://i23.photobucket.com/albums/b3...r/Jan29029.jpg
