Over fueling
Car is my 84 RX7 with a 12A
This was my surprise... well at least it was to me. I go to start my car to empty the last of the fuel out of the fuel system. The fuel pump is disconnected (wires cut awaiting a factory style replacement). So here is my question what would cause the carb to fill to the brim with gas? My assumption is a fuel pump pushing to much fuel to the carb. Aftermarket pump routed in the car hooked up the auto trans connector by the shifter. If I am right then I am assuming that would cause about .25-.5 gallons of gas to end up on the floor of the garage by going out of the exhaust system I do have to admit I found all of my exhaust leaks this way.:rofl: So to make this short as possible since one of the PO decided to replace the pump halfed ass it over fueled the carb causing fuel to come out of the exhaust of the car. If I replace the fuel pump and do it correctly then my fuel pump will not over the fuel the carb and that should correct my over fueling issue. Is there any other things I can do to prevent this from happening again? |
could be trash in the float needles causing it to not shut off the fuel, or they're stuck. if the pump pressure is too much they also wont shut off the flow. in this case u just need to add a regulator. the stock carb only needs like 2-3 psi fuel pressure.
OK replace the old (aftermarket fuel pump) with a brand new OEM style pump. Here is my question now. When I go to start the car it just cranks I get no pump prime until I turn the key from start to run and I get a 1 second buzz from the pump. What would cause this and yes there are about 2-3 gallons of gas in the tank.
An 84 will not start the fuel pump until it senses spark on the secondary ignition. In other words, it won't start the pump until you are cranking the engine over.
If your Float Bowl Vent Solenoid is not working, it will cause fuel to flow into the carb after shutdown. That is where I would start looking. . |
OK fuel pump issue resolved it works!!!!!!!! Had to reconnect the choke lever. Now I have an issue of fuel getting out the exhaust and a very lean condition with heavy smoke. So now my next question would be what would cause fuel in the exhaust and heavy white smoke?
Note: Plugs are new and gapped correctly, fuel is fresh, 8 gallons apx in the tank, I am about 100% sure the carb is way out of adjustment (was told it was rebuilt), |
A stuck float would cause the fuel issue, but white smoke could be coolant seals...
There are two floats. Large amounts of fuel can cause white smoke. What does it smell like?
Gas. I do not have the "sweet smell" ass. with coolant. Next on the to do list is rebuild the carb, well new gaskets, and new floats.
| All times are GMT -5. The time now is 07:56 PM. |
