Bolt in Ford 8.8 rear end with custom 4 link FOR SALE
I am getting rid of some projects around the shop. This came out of my 10 second running FB. It bolts in to your car without fabrication. Drive shaft and transmission can be sold as a package deal.
It has a locked full spool, Ford motorsport 4.30 gear and pinion, Mosier diff cover, Strange 31 spline axles with 5 by 4.5 lug pattern. Shortened an inch or 2. Fits FD wheels awesome. Has adjustable 4 link and panhard bar. 26 by 10.5 ET streets fit perfect under the back. It can be pulled out totally with shocks and everything attatched. Don't worry about breaking this one! $1200. Will be easy to install. Pick up only. You may also be interested in this! http://rotarycarclub.com/rotary_foru...824#post171824 All three pieces, rear end, transmission and driveshaft for $1500. Bryan@BNR 205 640 1193 |
do you have picture of setup
| All times are GMT -5. The time now is 10:46 AM. |
