-   Introduce yourself!! (https://rotarycarclub.com/forumdisplay.php?f=64)
-   -   Hello from spain (https://rotarycarclub.com/showthread.php?t=14865)
Jonathan3009 10-23-2011 02:09 PM
Hello from spain
Hello everyone! My name is Jonathan, I'm from Peru but actually im living on spain I just bought an Rx7 (stock) and I wanna start with the reliability mods... (gauges, Ast, etc) and as you can imagine is a little bit hard to found information for this car about how to's etc etc So I'm here to make questions and hopefuly get your help :p
speedjunkie 10-23-2011 06:04 PM
Welcome! I'm don't know if there is a list of reliability mods on this forum, but they are probably here somewhere. If not, we can help you out.
Jonathan3009 10-23-2011 07:46 PM
Yeah! i found it somewhere else... I'm gonna start replacing the AST and installing gauges... (boost, oil press, oil temp and water temp) now my problem is that I don't know what could be the best place to install the sensors for the oil gauge and where to install the water temp gauge... I was planing to use a oil filter adapter to install the oil gauge senders but I've read that is not a good idea due to it leaks... so if there is any suggestion or any advise about where to install the senders I'll appreciate :P
lt1_fd3s 10-23-2011 09:27 PM
i end up in marbella every now and then with work... welcome..
speedjunkie 10-23-2011 11:44 PM
Another reliability mod is replacing the downpipe (getting rid of the pre-cat) and possibly even the other stock cat, replacing it with a high flow cat or a resonated midpipe, or even a straight through midpipe if you want it to be ridiculously loud like mine was HAHA.
For the oil temp and pressure senders, I got the RE Speed filter mount. It has two ports for the senders and I've never had a problem with it, works great. The water temp sender I currently have mounted in a hose going from the top rear plate of the engine to the water filler neck, using a t-fitting I made from Home Depot parts haha. Normally that hose goes from the rear of the engine to the back of the throttle body, then it goes from the bottom of the throttle body to the filler neck. I might move it because I've been having problems with my gauge reading the temp correctly, but my old gauge was fine so I'm not sure what's up.
Jonathan3009 10-24-2011 07:08 AM
HI! thx for replying... I have a JDM RHD rx7... so, I've read that JDM rx7's does not need to replace the Downpipe...
I was thinking on use too a sandwich.. to fit the senders... but i found some info saying that with time that location tends to leak...
I think I'm gonna start a threat asking for suggestion tips pros/cons to install the oil senders
thx!
speedjunkie 10-25-2011 03:16 AM
http://mrcmfg.com/catalog/product_in...products_id=72
This is the one I have, it replaces the stock on and so far I've had no problems with it. I don't know anything about the JDM downpipe, you're probably right.
Got any pics of your car?
