-   -   A/C repair & restoration options (https://rotarycarclub.com/showthread.php?t=14406)
Pete_89T2 07-04-2011 07:06 PM
Well after 22 years of providing ice-cold A/C, my '89T2 is having trouble cooling down the cabin. Just last week it was blowing ice cold air (better than my newer cars), but today it was blowing barely chilled air. Checked the sight glass per the FSM procedure, and I've got the bubbles showing, plus the low pressure side plumbing to the evaporator core is just slightly cooler than ambient temp (it should be ice cold when A/C is running). Compressor seems to be running fine; clutch engages, and it sounds normal as compared to how it used to sound when all was well.
This means I've lost some R12 freon, and there is most likely a leak to hunt down, fix and then properly recharge the system with R12. Since I don't have A/C service tools, looks like my options are limited to finding & bringing it to a competent shop - living without A/C is NOT an option. So here's my questions...
1. Anyone know of a reputable auto A/C shop in the northern MD/DE/PA tri-state region?
2. Fix the system & stick with R12, or bite the bullet and do the conversion to R134a? I think the R12 route makes better sense, despite the expensive cost of R12, since I've read you pretty much have to replace a good portion of the A/C system components if you switch over to R134a - true?
Makes me long for the good old days, when you can buy R12 for a few bucks a can anywhere without an EPA license and fix it yourself.
88turboii 07-04-2011 07:49 PM
Just do it yourself. buy a o-ring kit and the r134 adapters, take all the lines off in the engine bay and replace the o-rings. not too difficult at all. invest in a a/c gauge kit, hook up to low side and charge with r134 to ~40psi on the low side with a/c running full blast.
im running r134A with no problems, runs cold enough for charleston, sc
djmtsu 07-04-2011 09:03 PM
Yep. Just get an O-ring kit (many of the Ford kits have all the seals you need) and get the 134a adapters.
You would benefit from taking it to a shop and have them completely evacuate the old R12 out. It really is an easy job.
RETed 07-04-2011 10:42 PM
I would recommend going the purge and fill with R134a route.
I have a 1990 Toyota Cressida as a daily driver, and I went with the R134a as per recommendation from my AC guy.
I too read all the negatives of R134a (versus R12), but I'm pleasantly surprised how well the R134a has held up.
I got 61F (at the vents) on a calibrated thermometer when we first did the job.
(Minimum temp is 65F according to the AC guys.)
Since you gotta crack the system open to check for leaks, you might as well replace all the o-rings (to handle the R134a).
Also, you need to vacuum everything out anyways, so it's a no-brainer to go R134a.
Ask if you can slightly overfill the system with R134a - this is the key to get everything real cold enough.
The stock compressor should be able to handle an extra half pound of R134a no problem.
With all the headaches associated with R12 (i.e. licensing and PRICE), it's nice to be able to run down to the local auto parts shop and pick up a 16oz. can of R134a for $10...
NoDOHC 07-05-2011 11:03 PM
I used stuff called Freeze-12, it is an EPA-approved alternative to R12 (uses the same lubricating oil type) I got a couple years out of it. I blew an o-ring just recently and have not got the time to fix it again (besides, I will hurt the environment if I work on my own AC in Wisconsin, so I have to drive into Michigan in order to do it...)
tweiss3 07-06-2011 05:32 AM
Try finding freeze 12, i just went through this song and dance last month, you can't find shit. Its now 134a or nothing.
MaczPayne 07-07-2011 02:48 PM
http://forums.vwvortex.com/showthrea...t-R12-to-R134a
I get my Freeze 12 on ebay, if you want to stay with an R12 type refrigerant
jackhild59 07-13-2011 03:50 PM
1 Attachment(s)
One other possibility is that your cooling fan clutch is beginning to fail. Don't neglect to check that out first.
Freeze12 is a perfectly fine replacement for R12, but you shouldn't mix it with the R12. Most shops won't work with Freeze12, so you will be on your own if you go this route. They will also encourage you to convert to R134a because they succeed with this most of the time. You will not be happy with the results. They will ultimately not be able to help you, consider that you are really on your own right now.
R134a is not a good replacement on our FC's because the FC does not have adequate condenser area. The conversion will work great if you add a larger *capacity* condenser. Other cars with large condensers would also make good candidates for conversion. Ted's Cressida falls in this category.
Before you do anything, you should find the leak. Use a soapy solution and a squirt-bottle to check all the connectors and rubber hoses. Look for bubbles.
If you don't find bubbles, you are probably just losing freon at the compressor shaft seal. Those seals leak some on all compressors, more as they age. That seal relies on oil to seal to the shaft as it rotates As the seal ages, it will leak more. One solution is to make sure to run the A/C at least weekly for 5-10 minutes to lube up that seal.
Don't take apart any connection that is not leaking just to replace the o-rings. Not necessary. If you do take a connection apart for any reason, do replace with the green oring.
Center vent temps at 50 mph, fan on high, set on recirc should be in the upper 38*/42* on a hot day-95*f+. R12 and Freeze12 can do this in the FC. R134a will likely be in the upper 40's lower 50's. This is a very big difference in capacity.
Good Luck!
-jack
MaczPayne 07-13-2011 05:23 PM
My FC gets to around 40 with Freeze 12, in Riverside heat :)
Only downside is my fan isn't ducted because of the huge radiator, so cooling is a little worse when I'm stopped in traffic
jackhild59 07-13-2011 05:37 PM
Nice.
Mine is R12.
Pete_89T2 07-13-2011 07:29 PM
Here's an quick update on my A/C problem. The stock fan clutch works fine, as does the aux. e-fan for the A/C condensor, and all the ducting is in place. Picked up a loaner manifold/gauge set at my local Advance auto parts store and did a little A/C testing this past weekend per the FSM.
Before doing the FSM tests, I did a quick static pressure check (engine not running/AC off) to estimate how much freon leaked out. The high & low sides were equal at about 86 psi, and the ambient temperature was about 85*F. So that tells me I should have at least 50~75% of a full charge. If it was much lower, it would mean a greater % of the freon leaked out.
Then I did the running test, A/C on max, 1500 RPM per FSM, and my low side pressure was 6 psi, high was 110 psi. FSM states recommended action for those results is to evacuate system, check for leaks & recharge system. Since I don't have a vacuum pump or any means to recover my R12, what I'm going to do is just recharge it myself with R12 and see how long it lasts. One can should do the trick, R12 can be had easily enough on ebay, albeit it's getting pricey.
BTW, I did some research on Freeze-12 and other R12 alternatives out there, and I would not recommend using Freeze-12 or any of the similar alternatives that are based on hydrocarbon gases. Most of these are highly flammable, based on butane, propane and other HC gas blends. The idea of running a flammable gas at high pressures thru crash vulnerable areas of the car and into the passenger compartment is a bit scary.
MaczPayne 07-13-2011 10:21 PM
Freeze 12 isn't based on HC. This is why I use Freeze 12.
Freeze 12 is 80% R134a, and 20% R142b, as listed by the EPA
http://www.epa.gov/ozone/snap/refrig.../refblend.html
RETed 07-13-2011 11:21 PM
This is a very good and important point.
The FC is one of the very few cars that *overheat* when you turn on the A/C.
This implies the condenser core is too small.
Most times, most cars will cool down due to the A/C dedicated aux fan running on top of everything else.
jackhild59 07-14-2011 12:16 AM
Couple of things: as macz said Freeze12 is not HC.
Next your charge is either very low or it is contaminated. You cannot tell the % charge from the pressure.
The low side pressure switch cuts the compressor out at +/- 18psi, so that 6 psi number is troubling.
I think your plan to evacuate and recharge is a good one. Put *exactly* 2-12 oz cans in. Factory charge is 26 oz. 24 is as close as you can get,'unless you find some really old 14 oz cans that sometimes show up on eBay.
Good Luck!
Pete_89T2 07-14-2011 01:05 PM
My mistake, confusing Freeze12 with "envirosafe" and a few other products being sold with names similar to Freeze12 that are HC gas based. Point I wanted to make is be careful with alternatives - some may work very well, but have unintended safety risks that aren't worth it
You can estimate % of charge remaining from a static pressure test, based on the ideal gas law, but it's a rough estimate. Quick ideal gas law reference:
http://en.wikipedia.org/wiki/Ideal_gas_law
The gist of it is the A/C is a sealed system, so volume is a constant, and the mass/# of gas molecules is supposed to be a constant, assuming no leaks. That leaves pressure & temp as your only variables, and these two are directly proportional. Since I was reading a high static pressure, it means I still have the majority of R12 in my system. Would need to consult with a temp vs pressure characteristic curve for R12 and know the exact mass of the original R12 charge to estimate the percentage remaining though.
This is interesting, and I probably should take a second look at the electicals... Didn't think I had an issue there since the clutch was constantly engaged while the A/C was on, turning the compressor. Does the pressure switch cut out the compressor ABOVE 18psi or does it cut out below that threshold? If it's the latter, at 6psi, my compressor shouldn't be running at all.
Yeah, I'm crossing my fingers on a couple of ebay auctions for the R12, but I might just have to spend the bucks on a "buy it now" deal -- seems someone always outbids me at the last minute on the damned auctions!
