-   -   Torque specs for rear gear bolts (https://rotarycarclub.com/showthread.php?t=14375)
JustJeff 06-27-2011 09:27 AM
I'm making a checklist for engine assembly using my Atkins DVD, FSM and Haynes. I can't find torque specs for the rear gear bolts. Neither FSM or Haynes list them and I don't have the sheet that came with my Atkins DVD
Are rear gear bolts the same torque as front gear?
Front Gear are 12-17 lbs
Pete_89T2 06-27-2011 10:53 AM
Sounds like a reasonable assumption, if the front bolts are the same size & spec as the rear bolts.
RETed 06-27-2011 06:12 PM
Sounds about right...
My (poor) memory recalls about 20 lb./ft.
These are the ones with the "lock" washers on them?
If these are the stock ones, you can't torque them down too hard anyways.
I've seen a lot of them snap from too much torque. :(
JustJeff 06-27-2011 07:58 PM
Yeah I found the answer and it's same as front gear. Unfortunately the assembly hit a snag. I got to installing water seals and found two of the four cracked in half. I'm about to create a thread about it if anyone would like to offer advice.
