-   2nd Gen RX-7 Engine Parts (https://rotarycarclub.com/forumdisplay.php?f=12)
-   -   S5TII Upgraded electronics package! N370 ECU w/ Rtek 2.0, sensors (https://rotarycarclub.com/showthread.php?t=14039)
FerociousP 05-04-2011 06:30 PM
I have run this setup for almost a year and has been my best running rotary to date. The RTEK reads and datalogs my wideband and I can make corrections and monitor values. Drove almost 700 miles to DGRRXI with no issues and hard running of about 10psi. This setup is ideal for near stock motors who want control over idle, cruise, and WOT fuel and timing. It allows you to keep OMP function, emissions... everything the stock system has, just allows it to be configurable. No wiring necessary (unless reading wideband.
Comes with major electrical components needed to do a s5 turbo swap. The Rtek 2.0 turns the stock ECU into a standalone allowing matrix control over fuel and timing, injector sizes, datalogging, omp on/off, alerts/warnings, and provides a configurable output. See the pocketlogger website for full details. http://pocketlogger.com/index.php?pi...age=2&ecu=S5T2
N370 S5 TII ECU w/ Rtek 2.0
N3A1 MAP sensor (Cosmo I believe, but values match my mechanical gauge exactly)
N370 MAF
Palm Zire71 and cables (for configuring and datalogging ECU)
$700.00 shipped to the 48 contiguous
If wanted, I will include a NA harness with new coolant sensor connector and is in pretty good shape. I used it on my car as I don't have emissions. If keeping emissions (or knock sensor or WG duty solenoid, you will need to repin or use a true turbo harness)
Midnight 09-03-2011 05:53 PM
PM'ed about the RTEK and Palm. Email me at SleepingOldGeezer@gmail.com
rotorbizle 09-14-2011 06:06 PM
Pm sent
My5ABaby 09-15-2011 07:56 AM
This is sold.
FerociousP 09-15-2011 11:09 AM
My B. Thread can be removed.
