-   -   Wiper issue (https://rotarycarclub.com/showthread.php?t=13980)
MmSadda 04-27-2011 11:20 PM
Wiper issue
Turned my winshield wipers on "2" today, and when I turned the car on later, the wipers wouldn't turn off. Interestingly, I think it will change to a slower setting when I turn the knob to "1" it slows down.
Would this be an issue with the relay or the switch? How should I go about fixing this? I need to get this taken care of quickly - I'm planning on going to DGRR in a couple days
Thanks
Collin
FRED 04-29-2011 03:34 PM
Next time it does this pull the plug off the wiper motor while the wipers are running (wiper switch in off) then put the wiper motor plug back on. Do the wipers start running again with the key OFF or not. Looking for a clue. Most likely it's one of the wiper relays inside the switch itself.
Or try this. Key to ON wiper switch OFF. If the wipers are not moving, well that's good. But now get a piece of elect wire bare at each end. PUt one end in the back of the Blue/Red wire at the wiper motor and the other end of your new wire to a nearby ground like the engine itself. Wipers should start wiping. Now unground your wire and see if they stop running or not. What happened? The Blue/Red and Blue/White wires are the wires that you put a ground on with the switch when you turn the wipers on. So you can also try this with the blue/white wire. Key must be ON and be sure your wiper switch is off when doing this.
No harm whats so ever will happen doing this IF your not color blind.
