-   Defined Autoworks (https://rotarycarclub.com/forumdisplay.php?f=215)
-   -   20b race/high performance header (https://rotarycarclub.com/showthread.php?t=13000)
GtoRx7 12-23-2010 02:18 AM
Here is another incredible piece from Defined Autoworks- Full race stainless header made to fit the famous 20b "3-rotor" engine when installed into the Rx-7 Chassis. Will fit both the FC and FD chassis (1986-2002 mazda Rx-7) Works with RHD as well!
What you are getting-
-Highest grade 321 stainless construction. Look up 321 stainless, it is FAR stronger and heat resistant than 304 grade. Its also MUCH more expensive.
-Fully TIG welded for superior finish, fit, and durability. Each header is hand fitted and welded. TIG takes HOURS to do, but is better than anything else on the market
-Dyno Proven and race tested design. This is not just a random bunch of tubes twisted together to look nice. This is a race PROVEN design after YEARS of research and development. Each runner is equal length down to a 1/4". The Collector has been carefully sized and made to provide tremendous power over anything else.
-Will provide more power on stock and highly modified non-turbo 20b's
Price is $2,150.00
http://i254.photobucket.com/albums/h...DSC01118-1.jpg
Herblenny 12-23-2010 07:47 AM
Simply beautiful work!
1twistedrx7 12-23-2010 08:16 AM
wow! great craftsmanship to bad my 20b is not na
GtoRx7 12-24-2010 04:14 PM
Thanks! We build turbo manifolds too ;)
