-   Old School Rotary (Pre-1979) (https://rotarycarclub.com/forumdisplay.php?f=39)
-   -   sa22 clutch cylinder in rx 4 coupe does a sa22 clutch cylinder bolt straight into an (https://rotarycarclub.com/showthread.php?t=12530)
dr50376272 10-12-2010 06:18 PM
does a sa22 clutch cylinder bolt straight into an rx 4 coupe?
regards
Buggy 10-13-2010 09:06 AM
I used a NA FC clutch slave cylinder on my rx-4. I had to lengthen the pushrod a bit by welding 2 nuts on it. Other than that it works fine.
dr50376272 10-14-2010 09:17 AM
can you upload some pics so i can see what you did ? thanks
