-   RX-7 1st Gen Specific (1979-85) (https://rotarycarclub.com/forumdisplay.php?f=38)
-   -   quick video of FC subframe in FB (https://rotarycarclub.com/showthread.php?t=10907)
Whizbang 04-04-2010 04:33 PM
check it out, i gave a quick go over on how i mounted up mine.
http://www.youtube.com/watch?v=1NmCfxRR_EQ
sen2two 04-04-2010 05:14 PM
dopeness... and suprisingly simple.
What are you doing for hubs/brakes/struts? FC also i would assume...
need RX7 04-04-2010 05:22 PM
Good stuff :icon_tup:.
Whizbang 04-04-2010 08:28 PM
you guess it. Just using the FB strut tops
sen2two 04-04-2010 09:00 PM
sweet... I thought about doing this to my Rx2. but when i measured the frame width, i found out its not even close to possible. sucks for me... good for all 1st gen owners.
Whizbang 04-13-2010 09:30 AM
well for the purpose of rally, i wont be using the FB tops due to issues with the spring seat. I am going to use subaru tops i believe for cheaper and easier reasons. Once im not a poor ass, i should have the front damper assemblies ordered.
IH8DSM 10-25-2010 08:46 PM
Using the front cradle bolt does that move the 2nd gen cradle forward any? I was wondering because i saw some where else that you have to cut out and re position both or it moves the front wheels to far forward.
sen2two 01-11-2011 07:29 PM
any updates on this?
Whizbang 02-23-2011 10:25 AM
actually kinda sorta yes. i ended up redoing the whole process on a different shell. But i used the FB springs (eibachs granted but stock should be similiar) and the tops on the FC strut. ill get pics here once its done.
Whizbang 02-23-2011 02:23 PM
ill probably make an updated video once the whole this is finished. Which should be soon. I just need some cursed FC 4 lug hubs!
