-   Tennessee (https://rotarycarclub.com/forumdisplay.php?f=172)
-   -   Middle TN - Thread (https://rotarycarclub.com/showthread.php?t=2317)
Johnny_K 04-20-2016 11:05 AM
Cool. I'll take them since I can't find mine.
project86 04-20-2016 11:32 AM
any one happen to know this guy?
http://www.rx7club.com/2nd-generatio...rsary-1095691/
almoststockfc 04-20-2016 12:21 PM
Them? Both?
FerociousP 04-20-2016 02:35 PM
Originally Posted by TitaniumTT (Post 328842)
:rofl: excellent... and that was just with some timing changes. It you wanna get froggy you can run 35* and some negative split and really lean it out. But watch your EGT's.
EGT's are the reason I run 30-35* and .92L at cruise.
Currently at cruise he's around 30-32, -5 split, and have the o2 correction set to 14.4 target, which it hits pretty well. Unfortunately he doesn't have EGT so that may be as far as its worth going to be conservative. Still smells but isn't eye watering. Will be using logs to create some delta tables to smooth the correction over (sprintRE doesn't have anything built in AFAIK).
Didn't touch timing much up high, so there should still be power to be gained when he gets on the dyno. He is going to need some, as the Jismo beat him from 40-100mph on the way home :eek: :rofl:
FC Zach 04-20-2016 02:49 PM
Originally Posted by FerociousP (Post 328987)
. . . so there should still be power to be gained when he gets on the dyno. He is going to need some, as the Jismo beat him from 40-100mph on the way home :eek: :rofl:
Hey now! ! ! Not by much, by any means :mad: lol
TitaniumTT 04-20-2016 02:52 PM
Kewl Kewl.... the negative split helps in cruise... it lets you lean it out farther than stoich in the quest for mpg. I don't on my personal car though, even with EGT probes I like it around .92L
:Chevy_anim: Time. At that point I think I would've pulled over on the side of the rd and torched it :rofl:
I don't remember exactly what the timing was up high, it looked pretty good FWIR so you really need to just play around with it. Some cars like timing around 30, some much higher. The most I've made was darrells ITS car. non cheater motor and I did 196rwhp. That fucker wanted 35*+ and I ran it @ .905L or 13.3:1 AFR. Other cheater motors (ported) like to see closer to .85L or 12.5:1. They're all cranky and need their own level of attention :lol:
djmtsu 04-20-2016 03:37 PM
Just like you.
TitaniumTT 04-20-2016 03:40 PM
Says the guy who "blew a coolant seal" and would rather drink than drive FrankenB
FC Zach 04-20-2016 03:40 PM
:rofl:
djmtsu 04-20-2016 03:49 PM
#1 - I didn't blow a seal, it was already blown. Or as I call it 'breached'.
#2 - Drink away my sorrows. Or drink then drive :D
project86 04-20-2016 03:59 PM
Originally Posted by djmtsu (Post 328993)
Just like you.
Oh he's not that bad......
TitaniumTT 04-20-2016 04:00 PM
1) I thought it was already shook down
2) Drink till the Dragon looks straight than get the keys
FUCKING PRIUS DRIVERS!!!!!!!!!!
:smilielol5:
djmtsu 04-20-2016 04:04 PM
1. If about 50 miles and 3 days counts as a shake down. Then I shook it like a shake weight. You saw the burnout? Were you not entertained?
2. 2017 goals.
project86 04-20-2016 04:10 PM
:smilielol5:
........ :squint: ....... I stand corrected.
I DROVE THE HIGHLANDER! :o21:
FC Zach 04-20-2016 04:17 PM
Same thing lol
